CARB IDLE
Old 05-27-2009, 10:28 AM
Tod74
How fast is it idling in park? Have you tried turning the idle speed up? Mine won't idle below about 1700 somethin' like that.
Tod74 is offline
Old 05-28-2009, 03:32 AM
JEFF69Z28
DYNO OPERATOR
SBC IDLE IS AT 1200 RPM.
JEFF69Z28 is offline
Old 05-28-2009, 10:29 AM
  #13
dparker
Jeff somethings you might check is..
Fuel pressure 7 psi
Idle screws out 1 1/2 to 2 turns
Make sure your needle seats are not running over
Check for vacuum leaks
Check vavle lash
I've seen guys drill an 1/8 hole in the butterfly to help to keep their engine from loading up.
A few things to check...........
dparker is offline
Old 05-28-2009, 10:35 AM
  #14
FullTimeRacing
DYNO OPERATOR
got mine around 1500 when hot
FullTimeRacing is offline
Old 06-01-2009, 09:09 AM
  #15
JEFF69Z28
DYNO OPERATOR
SCREWS WERE OUT 1.5 TURNS,TURNED THEM OUT TO 2 TURNS AND IT NOW IDLES FINE.
Old 06-04-2009, 04:51 AM
  #16
dparker
If turning the idle screws out another 1/2 turn fixed your idle, then you were to lean. The idle screws are a minimal change so your probably still a littel lean, if you have removable air bleeds on the top of your carb. You can put a smaller air bleed in the most outside air bleed from the vent tube to richen your engine at idle alittle more. Otherwise your probably going to have a bog at launch.
dparker is offline
Old 06-04-2009, 04:55 AM
  #17
JEFF69Z28
DYNO OPERATOR
I HAVE REMOVABLE AIR BLEEDS AND BOGGING IS A PROBLEM AS YOU CAN READ IN MY OTHER POST.IT LAUNCHES STUTTERS AND GOES DOWN THE TRACK FINE,LAST NIGHT COMING UP PIT ROAD IT HAD A MISS ALSO IT BACKFIRED THRU THE EXHAUST WHEN I LET OFF THE GAS AFTER MY RUN.
Old 06-04-2009, 04:56 AM
  #18
dparker
What jets are you running and what size is your carb.
dparker is offline
Old 06-04-2009, 05:07 AM
  #19
JEFF69Z28
DYNO OPERATOR
950 HP BODY 840 CFM CANT REMEMBER JET SIZE AS IM AT WORK.50 CC PUMP IN FRONT AND 30 CC IN REAR SQUIRTERS ARE 40 FRONT/40 REAR.
Old 06-04-2009, 05:17 AM
  #20
dparker
Anything over a 35 squiter I would have a .50 cc pump. I think your problem is that your to lean. Now to figure out where your to lean at. Make sure you don't have much free space between you pump lever and the linkage from the carb. It has a small bolt and nut with a spring in between. I think your close on the squiter size I run a 40 to a 45 depending on carb and air. On the air bleeds you can go down say 5 sizes on the idle air bleed and it will richen your idle circuit making your engine more responsive. I don't think it would hurt to go alittle bigger on your jets to see it that helps. I guess I should have asked, do you have an EGT?
dparker is offline
