-   -   CARB IDLE (https://www.racingjunk.com/forums/showthread.php?t=24392)
JEFF69Z28 05-27-2009 04:23 AM
CARB IDLE
WHY WON'T MY CAR IDLE WHEN I PUT IT IN GEAR.
dparker 05-27-2009 05:13 AM
I'd check torke converter may not be stalling right. If its a high stall converter it shouldn't effect idle to much.
TS1955 05-27-2009 05:24 AM
Possible vacuum leak!
TS1955
JEFF69Z28 05-27-2009 06:06 AM
CONVERTER IS NEW ATI 8 INCH.
I SHALL NOW CHECK FOR LEAKS AROUND CARB.
JEFF69Z28 05-27-2009 06:08 AM
HOW WOULD I KNOW IF CONVERTER IS NOT STALLING RIGHT?
hammertime 05-27-2009 06:30 AM
also check around the intake runners where it meets the head
dparker 05-27-2009 06:40 AM
Take the chips out and stall it up on the transbrake, see where it goes too. Usually on an eight inch converter, if your engine will idle fine in park it will idle in gear. Now if its starting to load up in park, you know its not the converter. You can check for a vacuum leak by putting your hand over the carb, it should pick up the idle. There is a number of things that will keep your engine from idling right. I just interupted that your engine idles fine when its not in gear and dies when you put it in gear.
CamBirdRacing 05-27-2009 07:11 AM
Cam isn't right.
JEFF69Z28 05-27-2009 08:57 AM
NO TRANS BRAKE,JUST REVERSE MANUAL VALVE BODY.IF YOU PUT YOUR HAND OVER THE CARB WONT' THAT CHOKE IT OUT?I DONT THINK ITS THE CONVERTER AS IT LAUNCHERS HARD WITH ONE WHEEL IN THE AIR.
JEFF69Z28 05-27-2009 08:58 AM
Originally Posted by CamBirdRacing
Cam isn't right.
THIS CAM WAS BUILT FOR MY MOTOR WITH THE AFR HEADS I ORDERED.
