-   -   Aviation Fuel in a high comp engine (https://www.racingjunk.com/forums/showthread.php?t=24899)
itsabird 07-12-2009 07:34 AM
i ran it back in the day so to speak, had no prob, always blended it with leaded fuel.
fla1976 07-12-2009 07:45 AM
AvGas
David, is this the info you were looking for?
Couple more takes on it.
http://www.waterfordhills.com/results/aviation.pdf
http://www.thumpertalk.com/forum/arc.../t-311517.html
wvhippie 07-12-2009 09:30 AM
Guys thanks for all the info. As always it has been a big help. :D
kwkracing 07-12-2009 09:32 AM
All i got from that article was they want you to buy expensive gas so they tell you how bad av gas could be.
fla1976 07-12-2009 11:27 AM
AvGas
I posted different views so everyone can read for themselves and decide what they want. I have run it and never had a problem. But, no matter what the subject, there is always another opinion. I never burned a valve or piston so I would run it again. I might've run better on race gas and been more consistent. The same goes with running alcohol. There are people that say it is hard on parts, but if you prepare the car for it's use you will probably be fine. When you take short cuts and don't think it through properly is when things go bad. JMO
mopar1962 07-31-2009 03:28 AM
pushing it at 12.5 to 1, if ya get caught somehow its a $25000 fine
desoto30 07-31-2009 09:32 AM
Originally Posted by Tod74
What is the difference between AV GAS and "CAR GAS"?
one of several/many differences is that av gas has an anti icing agent added to the fuel.
