bbc heads?
Old 01-25-2012, 09:03 PM
  #31
mwbrasher
Member
JUNIOR BUILDER
great...thanks for clearing that up... we are cool... just wan't to race... just like every one here....
mwbrasher is offline
Old 01-26-2012, 07:38 AM
  #32
TheYellaBrick
TheYellaBrick's Avatar
Racin', roddin', and renchin', is all about turnin' and lernin'.
:shock: :shock: :roll: :roll: ops: ops: ops:
TheYellaBrick is offline
Old 02-02-2012, 06:58 PM
  #33
bixblk
DYNO OPERATOR
bixblk's Avatar
Default 496 bbc
I got a great deal on a BBC apart for inspection,it should make 750 plus HP alum dart heads, great pieces for a great price
check out my Ad #2460715 $3800.00
Dart, eagle, comp, freshly machined block, ready to go Check it out
You can put it together and have a boat load of HP for cheap money
Call if interested or if you have any questions
jeff M 708-308-0282
bixblk is offline
Old 03-09-2012, 08:02 PM
  #34
burgessdg
JOURNEYMAN
Default BBC heads
What's wrong with a set of Rect port closed chamber factory heads? I have never seen a flow bench test on those old heads, but nobody can tell me oval port heads flow better than the old L88 heads without showing me some flow bench data to prove it. I too ran 10's with an L88 .60 over in a Nova. 488 gear, tunnel ram w 2-600 holleys. Those heads were on all high HP BBC 65-70, they should be plentiful.
burgessdg is offline
Old 10-25-2012, 08:59 AM
  #35
waynesworld154
Member
CRAFTSMAN
just a thought i run a 427 closed chamber motor cast head 291 have 320 runners from factory have a 2700lb car and run 5.90 115mph so dont give up on cast heads yet u can make plenty of pwer with cast heads just my opinion thanks
waynesworld154 is offline
Old 10-29-2012, 12:23 PM
  #36
oldandtired
oldandtired's Avatar
The closed chamber "bathtub heads" required a lot of work and then they still would not flow well in the upper RMP range. They were "OK" for a 396/427 but not for anything larger.
Too much valve to head chamber flow interference.
oldandtired is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
