hawk racing rods?????china but so it eagle
Old 09-15-2007, 04:24 PM
  #31
Tod74
What about all that procomp stuff on ebay? like stainless rockers and what not...that stuff worth a crap or no?
Tod74 is offline
Old 09-15-2007, 06:11 PM
  #32
zipper06
I bought a set of stainless 1.6's just to have them on hand. they in no way compare to comp cams or crower. In fact the front rollers have .002/003 clearance on the pin. They would probably be o'k for a flat tappet spring with maybe 135/140 seat pressuse but after looking at these i wouldn't put on a set of PSI's valve springs with a 260lbs seat pressuse on them. I just wouldn't trust them that far.
zipper06 is offline
Old 09-16-2007, 07:09 AM
  #33
Pwmax
You have to be very careful buying some of that really cheaply priced chinese parts. Some of it is absolute garbage, some of it, is actualy pretty decent. Buyer beware. Personaly, anything to do with valve train, I would stay away from. That has to be the biggest cause of engine damage/failures there is. When a rocker arm is described as follows, "Excellent for budget, low lift applications. Needs good oil supply and low spring pressure to survive. ". That is an actual description of a set of roller rocker arms. Yah, that wording sure instills confidence in my mind.
Frank
Advanced Performance
www.get-ap.com
Pwmax is offline
Old 10-03-2007, 06:46 AM
  #34
upstand
APPRENTICE
I have a 383 with all china/cat crank , rods , roller rockers , balancer , flexplate. It's been to 7000 rpm alot and held together with the exeption of eating up the rear main bearing the first summer.
upstand is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
