OIL PSI AT END OF 1/4 MILE
#21
I run a car quest which is made by WIX but that's just because of what I've read no personal experience. I have an UNCLE that only runs FRAM RACING filters on his stock car. I told him about their bad rep but he refuses to change. Said he has ran them for years.
#22
Originally Posted by Tod74
Have any of you had any first hand experience with a failure due to a fram filter,or are these comments based only on the bad reputation they have?
#23
You want some CHEAP INFO?
Go Buy a 3 dollar Fram Filter and Take a Wix Filter.Cut the OPEN and LOOK at the Difference in Workmanship,along with the Componenrts!@\
ANYONE that would Still USE a Fram Filter after seeing what there made of,HAS Lots of EXTRA $$ to SPEND!!!
Take a LOOK................?
Later
G 8)
#24
Later
G 8)
#25
I had a 1970 chevelle street car back in the 80's and I was driving down sibley blvd and lost oil pressure, It was a motor that had about 200 miles on it.BBC 402 I pulled over and towed the car to my house, checked the oil pressures gauge and lines etc. Drained the pan and stuck a a coat hanger in the pan and banged around hit the oil pick tube. I could feel it and hear it I knew it was off the pump. Any way pulled the motor and replaced and brazed the pick up back in no harm or foul. I was younger and thought it would not be hurt. It was not hurt ,but I was not spnining it hard just street driving
Hope this helps
Hope this helps
#26
http://forums.racingjunk.com/viewtopic.php?t=7762
#27
DYNO OPERATOR
FINALLY HAD CHANCE TO CHECK OIL $ FILTER FOUND 2 SMALL NEEDLE BEARINGS IN FILTER.OIL LOOKED GOOD AFTER STRAINING IT.INSERT MAGNET INTO OIL PAN FOUND SOMETHING IN BOTTOM OF PAN,GOING TO PULL MOTOR NEXT WEEK,I WONDER WHAT IT IS.......
P.S.
THE FRAM FILTER WAS COLLAPSED NEVER AGAIN WILL FRAM JUNK GO ON ANY OF MY VEHICLES!! AND YES IT WAS A FRAM RACING FILTER.
P.S.
#29
P.S.
P.S.
BTW it was probably about 1985 or '86 and a guy I knew had a Wix filter come apart on a 302 in a Maverick. I don't know if it was the parts store that sold it ( local store called Mr. Auto Parts now is a Napa) or Wix, but they paid to have his motor rebuilt. I was scared to use a Wix for years, but that is the only time I have ever heard of a Wix going bad and they made it good so that should say something about them.
