Oil pressure
#21
No the rocker setup is just like chevy's each one has a bolt to hold to head, oil's thru pushrods like chevy's, now that is one thing i haven't looked at, the mounting of pump to rear main might be something there oil spraying back to pan Hmmmm, Well, Well
#23
too bad they didnt make a see through pan to see if that was the issue of course guy could take an old pan cut a window in it an use peratex and rivits with a peice of plexi glass to make one
#26
Originally Posted by mopar1968
I am thinking a oil passage is cracked somewhere in the block, This job is now costing me money, Lossing my A$$ on this one. No lifter bore's checked out great engine had 134,000 before rebuild.
''JUST MY TWO CENT'S WORTH''
#27
Does the engine have galley plugs behind the timing cover like the small block Chevy. If it does, I would agree with KWKRACING and MANIAC that it may be the problem. There is no obvious leak that is visible, but the oil is not going to go to the top end.
#28
#30
check out this page http://www.forabodiesonly.com/mopar/...ad.php?p=68234 they are talking about loose oil galley plugs causing low pressure.. read the whole thread , they talk about 2 different ones...hope this helps
