Oil leak
Old 05-13-2009, 08:16 AM
  #21
SVRE
JOURNEYMAN
I had a front cover leak there once on the dyno, so we took a high powered shop vac and taped the hose to the valve cover breather, taped the other valve cover breather off, and put silicone on oil pan/timing cover seal and let the vacuume pull the silicone in good. Worked like a champ that time anyway. Just dont get carried away and fill the pan full of unneeded sealant!
SVRE is offline
Old 05-13-2009, 05:41 PM
  #22
mopar1968
mopar1968's Avatar
It's a ''CHEBBY'' what else do you expect :?: :?: Leak's- knock's-Rattle's-Misses- or just plain Blowing up :!: :!: :lol: :lol: :lol:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
mopar1968 is offline
Old 05-13-2009, 07:19 PM
  #23
whitey70ss
I had enough room to drop the pan down and clean the area with some brake clean and shoot some goo on it :lol: I hope it works. I'm not gonna fire it up till thur. or fri. I think I'm goin go to the truck pull and forget about the chevelle for a couple nights!
whitey70ss is offline
Old 05-13-2009, 08:57 PM
  #24
Tod74
Man...if I had the pan loose I would have put a new/correct seal in there...the only reason I said use the RTV goo was to avoid taking the pan down.
Tod74 is offline
Old 05-14-2009, 05:28 AM
  #25
whitey70ss
I checked the numbers and it is the correct seal, correct pan, correct ti ming cover. The felpro seal I have said its reusable so I'm gonna try it . If it leaksits coming out and gettin fixed right . I cant stand oil leaks. :x
Old 05-14-2009, 06:07 PM
  #26
whitey70ss
I got all my stuff from UPS today. The fed ex guy brought every thing but the carb fittings. ( imagine that!!). They said prob. tomorrow!
Old 05-14-2009, 10:20 PM
  #27
cepx111
Typical of UPS, probably was under his seat.
He'll deliver when he feels like it, should of used FEDEX!
cepx111 is offline
Old 05-15-2009, 11:26 AM
  #28
mopar1968
mopar1968's Avatar
If you can't stand oil leak's then don't buy a ''CHEBBY'' your just asking for trouble :!: :!: :lol: :lol: Well on second thought at least you know the underbody won't ever rust with all that oil on it :!: :!: :!: :lol: :lol:
Old 05-15-2009, 12:05 PM
  #29
MEMRACING62
AW COME ON, MOPARS LEAK SO MUCH OIL YOU COULD USE A MOPAR TO WATERPROOF YOUR DRIVE WAY :!: :!: :P :P
MEMRACING62 is offline
Old 05-15-2009, 12:08 PM
  #30
dparker
Isn't Triumph and Mopar built at the same plant?
dparker is offline
