batterys
![Default](images/icons/icon1.gif)
Many of the top brand batteries are made by U. S. battery. They just change the decals and casings for different brands. U.S. Battery has two plants here in Augusta, Ga.
95% of the time it's NOT the batteries fault. Undercharging, OVERCHARGING, bad ground / bad positive, or poor wiring in general or a bad starter is the reason the battery failed.
Originally Posted by wazup
I beleive that the warranty should start from the date of purchase and not from the day it was maid.
#13
APPRENTICE
COULD ANYONE HELP THIS DUMB MAN ON BATTERY ISSUES I HAVE A 12 VOLT SYSTEM NOW DO I HAVE TO CHANGE EVERY THING IF I WANT TO GO TO 16 VOLTS AND DO THEY MAKE A 16 VOLT ALT WATER PUMP OR CAN I JUST CHANGE THE BATTERY EVERYTHING CAN STAY THE SAME
#14
NO WAY WOULD I EVER GO BACK TO 12 VOLTS. (Well, unless she was really rich. lol)
#15
If you do switch to 16v make sure you dont use your 12v alt
#18
THANKS DAVID AND A THANKS TO YOU RABBIT IM JUST GOING TO CHANGE THE BATTERY TO 16 VOLTS HOPE IT WONT HURT FUEL PUMP THANKS GUYS :?: :?: :?: :?: :roll:
