Dropped a valve
Old 11-15-2010, 03:51 PM
contagious
Default valve
Took my time putting this together.Used adjustable pushrods to get the right length to get the roller in the center of the tips.they move from the center,forward about an 1/8 back to center,used dye to check.They were a little off center on the exh,but not any where close to off the tip. You never know when its up and running i guess,something was WRONG. :roll:
contagious is offline
Old 11-15-2010, 04:27 PM
TheRabbit
TheRabbit's Avatar
Something has to be wrong and looks like the guys are already giving some good tips. I just wanted to add that sucks and I hate to hear anybody breaking parts. If the heads are aluminum they can be fixed no matter how messed up they are.
TheRabbit is offline
Old 11-15-2010, 05:07 PM
  #13
contagious
Default valve
Thanks,you are right something is not happy.!!!Built lots of engines,but i'm not a master engine builder,so posting problems and looking for ideas,thanks to all for advice,that's what i a'm looking for.Thanks again.!!!!!!
Old 11-15-2010, 06:47 PM
  #14
Tod74
YOU should set your pushrod length so that when you are at half lift the valve and the centerline of the rocker arm form a 90 degree angle. The roller tip won't likely be dead center when the lifter is on the base circle. On a BBC it will likely be toward the inside just a little,at least mine always are.Mine never start out centered up unless the pushrod is too long.
just my opinion I am far from an expert.
Tod74 is offline
Old 11-15-2010, 09:11 PM
  #15
zipper06
Just a NOTE, Tracy Smith dropped a valve at our RJ friends meeting at Byhalia in Sept. He broke the int valve head off on #2 cylinder about 1/2" up from the head. Luckly it went up into the valve pocket and didn't do a lot of damage to the head just a couple valve seats and some welding in the pocket. It didn't even punch a hole thru the piston, but beat it up pretty good. They were also Ferrea valves. I built the 388 short blk. but didn't install the heads. He was too tight on the valve to piston clearance. 6 holes was barely tapping the piston with the intake. I personally would not recommend less than .060 on the int. and no less than .100 on the ex valves. He says he checked the ex and they were around .080. Rocker geomertry was good according to him. He had .017 steel shim gaskets on a 48 CC head with flattop pistons, it's now costing him about $600.00 to put it back together, with .050 MLS gaskets. The short blk is a dirt cheap build, i mean less than $1,000.00 with cast steel crank, SIR rods and Hypereutectic pistons. Still in a 2950 lb Camero it ran best of 6.29 @ 108 MPH, with 1.27 60 ft times. (cam is special and i won't talk about it)
I'm not saying this was your problem, but i am saying that there may be a problem with some Ferrea valves.
Just making a point.
zipper06 is offline
Old 11-16-2010, 05:12 AM
  #16
TS1955
DYNO OPERATOR
My concern would be where it broke. I've seen valves break down around the head but never up around the top of the stem!
TS1955
TS1955 is offline
Old 11-16-2010, 06:42 AM
  #17
TheYellaBrick
TheYellaBrick's Avatar
I forwarded this thread to my brother, an engine builder extrodinar, and here is what he said;
I'm gunna pass on this one (as far as posting), too many variables and the guys have already said the obvious. Sounds like a combination of improper valve train geometry and possibly piston contact - the exhaust valve is really strong down at the valve head but not so strong up the stem, may have hit the piston and loaded the stem up high to cause it to crack, then fail - the damage to the valve didn't happen at idle! Just happen to come unglued at idle.
TheYellaBrick is offline
Old 11-16-2010, 08:42 AM
  #18
contagious
Default valve
There is no contact piston to valve,did the math and checked with clay,over 100 thous on the exh and more on the int.The other seven cylinders and valves are clean ,no contact marks on pistons or valves.The Rocker geomertry need's to be checked very well as i'm the one that set it up as well,there was a little off center movment if i remember,but nothing off the tip.needs checking again for sure.Thanks for the help.!!
Old 11-16-2010, 09:37 AM
  #19
curtisreed
curtisreed's Avatar
The one answer that gives no satisfaction to the OP trying to find a cause is, sometimes things just break! Really sorry for your misfortune.
Curtis
curtisreed is offline
Old 11-16-2010, 11:59 AM
  #20
contagious
Default valve
It's all part of the game,if you have thin skin,this game is not for you.!!!!LOL!!!! :lol:
