ran into another problem
Old 03-17-2009, 05:39 PM
Tod74
I've narrowed it down to something in the drive train.
Tod74 is offline
Old 03-18-2009, 05:39 AM
suicidebomb
Run it till it lets go, that'll remove all doubt about the problem. :P
suicidebomb is offline
Old 03-20-2009, 11:03 AM
  #13
bowhay
EXPERT BUILDER
well im pretty sure its the front pump in the trans
cus i fixed the leak and filled it up and it still makes the noise when slowing down
something else wierd though
the motor makes no noise but u can hear a small knock in the exhaust
bowhay is offline
Old 03-20-2009, 03:39 PM
  #14
Scooterz
Bowhay-
Please tell us the setup & kind of truck. There could many things that make weird noises when rolling... that you do not hear when you are still. I.E; Speedometer/cable (I had this at slow speeds on a truck once), U-Joints, rotor/caliper, etc... it will help to understand more about your vechile & what is been done to it recently.
I know this "knock" noise you hear when it is in the exhaust I think.... but that is usually not actually a knock. That is typical of a less than stellar exaust system. Get rid of the glass packs if you really want to hear the exhaust clearly. I think the knock is an illusion the glasspacks are creating at a low idle/rpm.
Scooterz is offline
Old 03-20-2009, 04:59 PM
  #15
bowhay
EXPERT BUILDER
it is an 83 chevrolet 1/2 ton with a brand new rebuilt 385
u joints are pretty new
i drained the trans and replace the filter and all seals
and just earlier today it knock just myseriously stopped
bowhay is offline
Old 03-20-2009, 05:06 PM
  #16
Scooterz
If it is intermitent, I wonder if you are getting pre-ign from timing or bad vacumn advance... you might consider cross ign between plug wires or a simple ign issue as well that might create that knock at certain RPM.
Scooterz is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
