what air pressure for big slix
Old 12-30-2007, 12:57 PM
I972Nova
EXPERT BUILDER
I am sorry my input wasnt helpful...
I972Nova is offline
Old 12-30-2007, 01:10 PM
olds48
NO WAY! EVERY BIT HELPS. THANKS FOR YOUR TIME
olds48 is offline
Old 12-31-2007, 07:25 PM
  #13
zcar
SHOW GUEST
Default Slicks air pressure
The best way is to watch your slicks on the edges after you have made a burn out, look at the very edge of the slick, you will have excess rubber build up where the slick is actually contacting the track. You want the excess to be on the slick edge, hope this helps, with your weight probally start out between 7-8 lbs.
zcar is offline
Old 12-31-2007, 08:27 PM
  #14
Tod74
I have a 3050 lb car with ladder bars. I run 8-10 pounds.
Tod74 is offline
Old 12-31-2007, 10:13 PM
  #15
olds48
Thanks all you guys
olds48 is offline
Old 01-06-2008, 07:23 AM
  #16
rob41willys
SENIOR BUILDER
I run 33x15 goodyears at about between 7-8 lbs. pretty light car with 4-link though. As far as the back end wanting to come around on the burn out if you can jack some weight in the left front that would help also. ( puts more load on the right rear )
rob41willys is offline
Old 01-06-2008, 11:23 AM
  #17
olds48
Sounds good.Thanks man
olds48 is offline
Old 01-07-2008, 01:28 AM
  #18
bowtie4542001
DYNO OPERATOR
I had 14.5x32 on a 2800lb Nova and was running 10lbs with no problem. I agree to call the manufacture though to get a rough esitmate. Then play around with it a little to get the best 60' times. Good luck and keep us informed.
Chris
bowtie4542001 is offline
Old 01-10-2008, 04:55 PM
  #19
fla1976
fla1976's Avatar
Default Tire pressure
With the tires inflated to the same pressure, check the circumference of the tires to see if they are the same. They may be different and the difference in pressure may equalize the size. I ran 7.5 in my Hoosier slicks. Both were the same circumference within an eighth of an inch.
Paul (fla1976)
fla1976 is offline
Old 01-10-2008, 06:01 PM
  #20
olds48
I can understand different pressures to equalize the rollout,is there a certain range the tires have to stay in?Like only a 2 pound difference or something like that?
olds48 is offline
