(( WARNING )) DYNOFLO ENGINES BAD DEALINGS
Old 04-03-2007, 06:19 AM
ilovedragracing
SHOW GUEST
Default Re: Look at the Pics & Take A Guess Give it your Best S
Originally Posted by fastbowtie
Hi Guy,s Take a look at the pics below and take a Guess at what happened
heres my guess... something broke.. i win
ilovedragracing is offline
Old 04-03-2007, 09:21 AM
Racing1968
SHOW GUEST
I would guess only one bolt torqued
Racing1968 is offline
Old 04-03-2007, 10:34 AM
  #13
slowman
looks like a eagle rod,send the rod back to eagle and they will tell you why it faild or send it to arp they would what to see if was there stuff or the builder. they can tell you if the bolt had the right torque on it.if someone built it for you just call and show them the parts with all the pics any one with half a brain can see what happened.i hope ho ever is a standup guy and stands behind there work.it sucks i have made the same mistake and i have been building engines for almost 20yrs.good luck jeff
slowman is offline
Old 04-03-2007, 11:36 AM
  #14
bbchevy
Default Guess?
ROD BOLT Failure!
Later
G 8)
bbchevy is offline
Old 04-03-2007, 11:52 AM
  #15
gimmemud
Looks like the rod cap is on wrong way.
gimmemud is offline
Old 04-03-2007, 12:15 PM
  #16
bbchevy
Default ?
All depends what you Call,THE WRONG WAY??????????? :shock:
Most likely them,Bearing Tabs should be Oppossed!Not mated.But,maybe thats 1 Of them SPEED Secrects?
Sorry about your LOSSES?I'm sure the Crank took some BEATING also?
Later
G 8)
bbchevy is offline
Old 04-03-2007, 12:50 PM
  #17
mcracecars
EXPERT BUILDER
what have we got here.
-rod itself looks ok on the small end
-rod does not look to be bent.
-rod bolts look beat but not broke or stripped
-rod cap looks bent
-lots of oil pressure.
-motor ran for short time.
I would say rod bolts not torked, backed out and hit the block somewere, bending the cap.
The poor bearing did not have a chance. :cry:
mcracecars is offline
Old 04-03-2007, 04:09 PM
  #18
fastbowtie
Ok Guy's, No more clues.
I will let the pics do the talking.
Now tell me what you think. REMEMBER, only 8 minutes run time!
fastbowtie is offline
Old 04-03-2007, 04:23 PM
  #19
slowman
i'm raising my hand,i know i know the pan jumped up and loosed the rod bolts.just like the tree walked into the road i hit.i would blame the guy in the ugly shirt he looks guilty.just kidding it still sucks. :cry: :shock:
slowman is offline
Old 04-03-2007, 04:58 PM
  #20
fastbowtie
Yes you are correct, the rod bolts were hand tight ALL 16 OF THEM .
One step completely missed.
The mains were torqued correctly.
A large engine builder built this short block that deals on Racing Junk.
Im not naming any names just yet, but I should after what he said to me over the phone and what he has said about me in emails to other people.
Bottom line is he has already stated that it is not his fault OR responcibility.
Hmm Does that sound correct to you :?:
I will settle this if he can talk properly to me & the owner of the engine.
He can PM me Before it escallates into a very major issue.
Every one that knows me knows I'm straight up and have no reason to lie about this. I diddn't build or modify the bottom end .
