compression ratio
Old 04-19-2009, 09:48 PM
  #21
Tod74
Originally Posted by Jordan1984
Yes I have done many compression checks .
Ok....
what is the compression ratio of an 8 cylinder engine that gets cranking compression readings of
234,237,232,234,233,235,231,236?
Tod74 is offline
Old 04-19-2009, 10:29 PM
  #22
suicidebomb
Tod, I came up with 234, or about 16.5:1. How bout it? Am I within a tenth?
suicidebomb is offline
Old 04-19-2009, 10:30 PM
  #23
Tod74
Tod74 is offline
Old 04-19-2009, 10:33 PM
  #24
suicidebomb
..........Tod ain't aswering, so I must be spot on..........Tod, give me a call, my number is BR549.
Old 04-20-2009, 02:49 AM
  #25
I972Nova
EXPERT BUILDER
Im done trying to beat the dead horse. You my friend do not have a clue about getting a compression ratio and you should find a new mechanic if he is telling you that there is a guage that gives you compression and not just cranking pressure.
Get any manual and look it up, or ask any full time mechanic, not a weekend backyard mechanic.
I guess real world wrench turning experience and ASE certifications take a back seat to the brilliance you can attain by reading a Haynes manual :roll:
I972Nova is offline
Old 04-20-2009, 03:10 AM
  #26
TopspeedLowet
DYNO OPERATOR
Thanks for saying this DragsterJosh, I think a little miss reading or real general source material "grossly misunderstood by the reader" must have caused this nonsense. I would have thought that when every one was :lol:, at this nonsense, the author may have re-thought his answer prior to insulting other race junkers that are politely giving him a reality check . Cranking compression has no relation to static compression ratio, DUH... Cam timing will have the greatest role in manipulating the cranking numbers up and down. Advanced cam timing settings will give higher readings and retarded settings will give lower PSI numbers, no matter what the calculated COMPRESSION RATIO is, changing only the cam timing without any physical volume or ie, compression ratio changes.
PS, We don't have to be a full time mechanic's to understand printed material in a repair manual, but it appears someone obviously does.
Bruce
Retired master ASE tech
TopspeedLowet is offline
Old 04-20-2009, 10:06 PM
  #27
radicalz
Ok....
Using his formula...I get the same answer as Tod...hey where...what the..
radicalz is offline
Old 04-21-2009, 08:38 PM
  #28
THERATTLER
THERATTLER's Avatar
not making fun or anything but you don't have a clue as to what you are talking about , if you think I don't know anything about motors , check out the picture by my name , I have built every motor ever been in this dragster , there is no compression guage that reads COMPRESSION RATIO , it reads pressure in pounds..SORRY
THERATTLER is offline
Old 04-21-2009, 08:52 PM
  #29
Jordan1984
Member
MASTER JOURNEYMAN
SORRY FOR GETTING MY INFORMATION MIXED UP AND GOING BY WHAT 1 INDIVIDUAL HAS TOLD ME- HE HAS BEEN RIGHT EVERY OTHER TIME THAT I HAVE WENT TO HIM FOR INFORMATION. I DID GET IT CONFUSED. MY BAD. IM NEW TO RACING, GETTING MY FEET WET AND LEARNING AS I GO, LEARNING FROM MY MISTAKES AND I HAVE MADE ALOT OF MAJOR MISTAKES ON MY WAY BUT I HAVE LEARNED FROM THEM. I WILL NO LONGER GO TO THE MECHANIC WHERE I WAS GETTING MY INFO FROM, I WILL TURN TO HERE FOR MORE INFORMATION. What mistakes have I made? I ruined a 200 4r trans, broke lifters and pushrods, wiped out the lobes on 2 cams. Even as far as getting my arm stuck in driver side header, droping the 7/16 to the floor, and waiting cramped up for my dad to find me 4 hours later. It might be a street car, but my ad number is 1526368 if anyone wants to check it out.
Jordan1984 is offline
Old 04-21-2009, 08:56 PM
  #30
THERATTLER
THERATTLER's Avatar
:lol: :lol: :lol: GOT YOUR ARM STUCK IN THE HEADER :?: :?: :?:
