My V8 S-10 (lots and lots of pics)
APPRENTICE
Never taken it to the track. Just street drove it with the 355. I might take it to the track one night to see what the 406 does. Friend of mine has a 55 chevy with a 355 in it to. He runs in the 7's at the local 1/8th mile track and I could keep up with him pretty well with my 355. From a stop he would get me because mine dont hook, but from a roll we pretty much stay side by side. He doesnt know about this 406 swap either. :lol: Hopefully this is a great improvement over the 355 I had and hopefully I can suprise him sometime. :wink:
#14
APPRENTICE
Well Im in love all over again. I havent even had it past half throttle yet and I am still tickled pink. Even taking it easy I can tell there is a lot more power and a TON of torque under that pedal. With the 355 at about a 30 MPH roll in 1st it would haze the tires and spin midway through second. I was coasting down my street at about 20 and just gave the pedal a good half throttle stab and it made the tires squeek. Should be interesting when I finally get on it. I didnt think gaining only about 56 cubic inches would make that noticable of a difference. No more cooling problems either. New radiator is great! Never over 160 idleing in traffic and never over 140 driving. Also met up with another V8 S-10 while I was out. He was kinda stupid though. He saw me behind him ( I dont have my hood on yet) and he mashed his throttle. He was all the way sideways on a 2 lane back road and when he lifted he was still sideways and spinning. So needless to say it hooked and jerked hard to the left. He about lost it. When I finally got up next to him he nailed it again and it poped through the carb and died. He probably thought I was a sissy since he kept showing off and all I was doing was crusing So far ripping out a perfectly good running 350 to put this 406 in was worth it!
#16
APPRENTICE
Originally Posted by olds48
Cool!!!Sounds good.Glad to hear you know how to enjoy a hotrod without endangering everyone around you,too.Have fun!!!
I do have one BIG issue though. Starting this thing. I have to put a charger on it and put it on atleast the 40 amp setting to spin it over fast. With a volt meter on it the battery goes from 12.48 to 8.67 volts during cranking. I would find it hard to believe the brand new starter is bad, but I guess it could be. Or maybe I should have got a 3hp gear reduction starter instead of a plain ole 2hp mini starter. I havent checked the compression yet, but I have a feeling its up there, so that might be the problem to. The battery is in the bed and ran/grounded all with 4 gauge wire. Thinking of going to 2 gauge on all of that to. It cant hurt. Sucks not being able to shut it off anywhere. Like today I was biting my fingernails with the gas gauge sitting on E. I had to make it home. While I was so worried about my gas guage I stopped looking at the others. I turned on my street and realized it was creeping up to 200 degrees. No big deal, but it has been running at 140-160. Pulled in the driveway, got out and the fans were not running. My new relay crapped out on me, so I put the old used and abused one that was in it with the 350 back in and cured that problem.
#17
How long are your battery cables?I ran 2 gauge on mine.They were about 18 feet long and had no problems.If you can,find some welding cable to use instead of regular battery cables.The copper strands in the welding cable are alot finer and there are more of them.Electricity doesn't flow thru a wire,it travels on the outside of the conductors.Strange but true.The more individual strands the lower the voltage drop.That is why cars can get away with such high loads on smaller stranded stranded wires,whereas the wiring in your house(solid conductors)have to be so much larger in diameter.I had a problem with a hard start condition one time and found that the terminal on the solenoid that the battery cable hooks to was loose on the solenoid itself.Big voltage drop there.
#18
APPRENTICE
The cables are probably 12-14 foot long. I replaced the longest one from the one side of the disconnect to the starter with 2 gauge welding wire today since I happened to have some. Seemed to help a little. Now I need about 5 foot more to go from the battery to the other side of the disconnect and some small pieces to re-do the grounds.
#20
What kind of disconnect do you have and how old is it?Some of them are not rated for the amperage it takes to start a car.746 watts equals one hp.Watts divided by voltage equals amps.So..if you have a mini starter rated at 2 hp that is 1492 watts.1492 watts divided by 12 volts is 124 amps!!If your voltage drops to 8 volts(which is not that uncommon if you watch your gauge) it would be 184 amps.ALOT of the cut-off swithches people use are only rated at 20 amps continous and 200 amps intermittent.Not much of a switch considering all the electronics some guys run.Water pump,elec fan,ign box(which is not much),1 or 2 fuel pumps,and then when you pull your lights on at night...20 amp switch barely covers your head/tail lights.doesn't take long to max out one of those babies.Check your switch.If it being overworked it could be losing alot of voltage where it has been overheated from over-amperage.Might be cheaper than buying alot of cable.Moroso makes a severe duty switch rated at 2,000 amps intermittent and 300 amps constant.Goes for about $60.Just a thought :?
