max tire height
Old 03-08-2008, 01:18 PM
olds48
That's just wierd :|
olds48 is offline
Old 03-09-2008, 08:40 AM
us7race
EXPERT BUILDER
Originally Posted by Tod74
Originally Posted by us7race
A taller tire would put more leverage on the wheels center.
Not sure how much it effects it, but it does.
so you think it is a legit concern? I know ( at least I think I know) I have seen big tired cars with thye convo pros and for sure there are a bunch of em with the Draglites.
The thought of forking out 400 bucks a wheel for the Magnums or AlumaStars kills me.
But if it is a real safety issue I will have to I guess...cause I can't stand looking at these old "Tricks" or "AutoDrags" or whatever they are any longer.
If it were me I would run them. I don't think the use in Drag Racing would hurt the wheels. On something with alot of weight, like a 4x4 or something you pull with it may be something to consider.
us7race is offline
Old 03-09-2008, 09:14 AM
  #13
fla1976
fla1976's Avatar
Default Max tire height
According to the manufacturer, there is a height limit for conventional tires but it does not seem to apply to slicks. Here is an excerpt from their website:
Featuring Center Line's classic racing wheels with the convulted outer. These top-selling designs have left their definitive mark on the street and track. This is a modular aluminum wheel manufactured by riveting two wheel halves together back to back. Wheels are light weight and designed to go fast and look great. These wheels fit the vehicles listed below and much more. Just check your bolt pattern. Typically to fit any diamter wider than 9 inches requires careful measuring and/or modifications to the vehicle. Call us at 800-345-8671 x5 to discuss any questions including fitment advice...we have lots of it as well as diagrams. Center section of Convo Pro is a satin/machine finish; the outer is brilliantly finished to a hi-polish shine for a striking contrast. 30-inch max tire size (OK to run taller drag slicks). 1525 lb load rating per wheel.
fla1976 is offline
Old 03-10-2008, 05:19 AM
  #14
Tod74
Default Re: Max tire height
. :wink:
Well the info I had was from Summit racing website. I looked on Centerline's Website and they do indeed say "30 inch tall tire limit"
BUT they say that does not apply to drag slicks.
http://www.centerlinewheels.com/whee...d=34&sw_id=364
Tod74 is offline
Old 02-21-2009, 06:57 AM
  #15
Natureboy71
SHOW GUEST
I am in a similar situation but going to be using 33x21.5 Mickey Thompson sportman bias ply street tires.
I was planning to go with Centerline Convo pro's but now wondering if I have to go with the much more expensive Weld Aluma stars?
What rims are guys using with tall street tires?
Natureboy71 is offline
Old 02-21-2009, 11:03 AM
  #16
Tod74
I'd weld two stock 15 x7's together before I bought anything from Centerline. THEY ARE SCUMBAGS
Tod74 is offline
Old 02-23-2009, 11:13 AM
  #17
Natureboy71
SHOW GUEST
ok then....well I guess that also leaves the Weld Woodward RT's. Not much else to choose from.
http://store.summitracing.com/partde...5&autoview=sku
Is anyone else out there running a back half car with street tires over 32", there must be.
Any advice? The Welds are fine, just wanted more options for style.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
