-   -   alldeck BBC Pushrod problem (https://www.racingjunk.com/forums/showthread.php?t=563645)
wlpatterson 11-15-2015 05:19 AM
Im building a BBC Talldeck And am having a hell of a time finding the right pushrod.I called Comcams and the Pushrods I have are .020 shorted than stock talldeck length but the tech says that's good.Im running a comp 282 Hyd cam setup and when I went to install the pushrods the Rockers will not reach the pushrod? Im running Brandnew Procomp Alum Heads And these are Edelbrock Pushrods.Is it a lifter problem? I know someone out there has had this problem before and I would really appreciate your help..you can Text me at 361-548-3327 or email me at [email protected] & thanx in advance.I don't know if it makes any difference but I decked the block .010 but to me that should make the pushrod .010 longer?
