Engine stalls when revving
Recently got back my sbf from machine shop , had it stroked to 347
Same time I changed heads, cam, tconverter Re assembled the components , engine fired immediately broke in the cam And every time I rev the engine 2500rpm + it bogs down then Stalls I've replaced wires coil and even the dizzy I chanced springs to bring timing on earlier I've changed the fuel pump, I have a regulator and gauge showing its working I'm still playing with the timing, as I'd like to get smaller bushings for my msd mech advance I have not got a vac reading on it yet, that's my next step, but I have ensured no leaks What do I look for next? I'm f*#%king baffled Here's my build so far Thanks for the help, appreciated >>>>>>>>> 23 T Bucket 2000lbs >>>>>>>>> 1968 Ford 302 >>>>>>>>> Bore .030 stroked 3.4 = 347ci >>>>>> Probe industries Forged Flat top 2618 aluminum Pistons 10.6:1 (475grams) >>>>>> Scat Crank 9000 material >>>>>> Forged Scat 4304 I beam Rods 5.4length with ARP cap screws >>>>>> Pro Street Dampener & SFI approved 157 tooth flex plate >>>>>> *4 deg cam advance >>>>>>> Comp cam # 35-246-3 >>>>>>> Duration at .50 is 230/236 >>>>>>> 110 lobe separation >>>>>>> .523/.523 lift >>>>>>> Hydraulic flat tappet >>>>>>>>> 180cc alum SBF heads 60cc >>>>>>> 2.02 intake valves >>>>>>> 1.06 exhaust valve >>>>>>> Springs Seat pressure: 132 lbs. @ 1.750 inch, Open Pressure: 293 lbs. @ 1.250 inch O.D.: 1.430 inch, I.D.: 0.697 inch Dual valve springs with damper Approximately .540 inch max lift at recommended installed height >>>> 7/16 push rods >>>> 1.6 aluminum roller rockers >>>>>>>>> x4 duel IDF Webber Carbs, MSD Pro Billet Dizzy, Mallory Coil >>>>>>>>>21* Mechanical Timing, ? Total Timing Advance, All timing in at 2500rpm (X1 light blue spring, X1 light silver spring) 110gph electric fuel pump >>>>>>>>> Trans 1968 C4, shifts @ xxx Rpm >>>>>>>>> Stage 2 shift Kit , w/extra clutch & A servo >>>>>>>>> 10" 2800 -3500 Stall TCS bracket master Converter >>>>>>>>> Rear End 68 Jag XKE >>>>>>>>> 3.33 Gears >>>>>>>>> Limited Slip >>>>>>>>> Independent Suspension >>>>> 1 5/8 primary tube w.3.5" collector Sanderson headers with Supertrapp adjustable exhaust >>>>>>>>> Tires 31x18.5x15 LT Slicks |
Nice! A freshly machined 347 stroker is a great foundation for a strong small-block Ford build. If you're already browsing, its paripesa section is worth a look too. It brings together popular casino formats in a straightforward online setting. Be sure to check eligibility, local availability, and the applicable terms first. Now the fun part begins—choosing the right heads, cam, intake, compression, and fuel system to match your goals. A well-matched 347 can make serious power while still being street-friendly. Can’t wait to hear how this build turns out!
| All times are GMT -8. The time now is 06:31 PM. |
