-   -   Not enough travel (https://www.racingjunk.com/forums/showthread.php?t=34848)
cervidog 07-07-2015 04:48 AM
Not enough travel
IF,I think my drive shaft has been bottoming out in the transmission what would the part affected.I have the trans out to inspect/replace pump and thought this mightbe a good time to chech other stuff.Pan/ filter were clean,only abou ten passes after last change but the trouble I was having was it took a long time for gear to engage when first started car. Once it did it worked fine? It's a th400.
BuckeyeShaker 03-30-2019 07:33 PM
I see you are from Grove,City Ohio. Give Steve Grady a call that lives in your area. I'm sure he can help.....
