Low oil pressure light and ignition cutoff safety switch
I am sure this has been brought up on here before, but need to ask one more time.. I would like to have a low oil pressure light as well as low oil pressure safety cutoff for ignition and was wondering if anyone has recommendation as to what switch and a diagram if possible of setup.
This is for drag race application. Thanks in advance.. Ron [email protected] |
Here are a couple links that should help. Save the diagram to "Paint brush" or similar program and resize it and print it out. The other link is for a 12 Lb switch. The momentary switch is for easier starting. I would leave out the oil pressure switch that follows the fuel pressure switch.
http://www.smileysracing.com/shoppin...i=60723&c=1730 https://encrypted-tbn2.gstatic.com/i...bCtPGqbyi1G5vs |
Thanks RacingJunkie for the reply... Is there a three connection type pressure switch on the market that will illuminate the idiot light with no or low pressure and an ignition cut out if falls around 15 PSI? Asking a lot but before I plumb in and wire two separate switches, just want to do some homework...
Thanks.. Ron |
http://www.summitracing.com/parts/mrg-7872/overview/
You could wire it to your ignition with a relay. |
^^^ Good setup.
| All times are GMT -8. The time now is 06:39 PM. |
