-   -   DrippingCarb (https://www.racingjunk.com/forums/showthread.php?t=34609)
wlpatterson 10-28-2014 02:37 AM
DrippingCarb
I have a Holly carb that drips after shutdown is the float too high or what? Thanx for your input
Harbone 10-28-2014 06:10 AM
needle and seat is usually the cause unless the power valve is blown out?
curtisreed 10-28-2014 08:05 AM
If the float is a little too high, expansion from heat conduction from the intake through the carb can cause it to drip also.
SuperComp1R 10-28-2014 01:43 PM
needle and seat.
wlpatterson 10-29-2014 02:48 AM
Thanx I will try that
BigBlockMark 10-29-2014 06:20 AM
When I have a dripping or overflowing issue on one end of a Holley carb, I remove both needle and seats and switch positions. If the problem switches ends I replace the needle and seat. If it stays at same end, I replace the float. (That is assuming you have the fuel level already at the bottom of the site plug or just below to see it is not a level issue.)
