Looking for dragster set up help
Have a 235 swing arm. 34.5 x 17x16 good years and 4:30 gear. Motor is a 588 on alcohol with glide. 5700 converter and starting line enhancer. Questions I have
Tire pressure Launch rpm Shift rpm Have lost my way a but in the heat this summer , all opinions welcome Thanks |
I would start at 5.5. You may end up around 5.25. Launch 4200-4600. Start at 7000 rpm on the shift. Without knowing much on cam and heads I would say that 7000 should be a safe starting point. I would ditch that converter and look for something in the 6400-6600 range. 5700 is a tight set up.
| All times are GMT -8. The time now is 08:21 AM. |
