632 crate motor + EFI+ Procharger=HP?
So I am no PRO motor builder and I am looking at a Street/strip Motor that will also run on pump gas.
I see 632cid creat motors that claim 800+ HP on pump gas, and that in itself is a ton of HP.I have a Pro-street 67 camaro that LOOKS amazing and is almost complete and was thinking of tossing in one of these motors and adding holly's EFI and a pro-charger to the mix. I have seen some crazy numbers with these compos and think it would be somewhat streetable. So any thoughts on this? Pros & Cons? Thank you in advance |
I would want to check the limits of the components in the motor. Rotating assembly and block would be my concern. You will probably be better off getting a motor configuration set up for a pro charger application.
| All times are GMT -8. The time now is 06:04 PM. |
