468 Alky motor missing on one side when warm
I have a 468 motor running flying toilet injection, solid roller,.642 lift cam,13-1 compression,brodix 2+ heads,msd6al. Motor runs awesome when cool,after warming to 185+ it will stutter on one side only. Any ideas?
Have you pulled plugs to see if you are lean? Are you running it that warm all the time?
Curtis |
The motor is in a mud truck, I usually will run about 15 gallons and then stop for a while then do it again. I replaced the plugs tghinking I had fouled one.
When its below 150* it runs great.
What did the plugs show that you pulled out? You can get an experts opinion by checking with Scott Offerman or James Monroe at http://www.killerrons.com/
Curtis |
| All times are GMT -8. The time now is 07:50 AM. |
