-   -   Electrical help needed (https://www.racingjunk.com/forums/showthread.php?t=34392)
holeshotta 04-05-2014 12:19 PM
i have a bb chevy dragster and went to track today and fuel pump fuse is blowing after ignition is turned on. Car sat all winter an neveran issue before. I have a painless 6 switch panel with fuses. i am thinking a ground or a damaged wire. Its a real pain to pull apart so wanted smarter people than me to weigh in. thanks for any help you can lend.
SuperComp1R 04-05-2014 03:22 PM
fuel pump is locked up
holeshotta 04-06-2014 08:53 AM
ran fine the day before for 20 minutes idling getting ready, will check however, thanks!
farnson 04-27-2014 02:47 AM
Disconnect wire at pump and pull the fuse. With an ohm meter check contiguity to the chassis. if you get a reading the wire is grounded to the chassis.
Good luck, electrical problems.....
shybx1969 06-05-2014 03:43 PM
yup i agree, somethings overloading..
