-   -   Need some expertise Help (https://www.racingjunk.com/forums/showthread.php?t=34385)
wlpatterson 04-02-2014 06:02 PM
I have a BBC427 talldeck 10.2 block I want to build..I have a set of Jahn std pistons but it wont stay std so Im needing a set of .030 pistons..My question is The Talldeck has a longer piston But Im reading you can use a reg 9.8 piston W/a 400 long??Im also understanding the 10.2 has an extra ring? I have a new set of .400"H"beam rods & a set Of .060 pistons for a 9.8 block will they work? [email protected]
oldandtired 04-03-2014 01:07 PM
You can use at 9.8 piston with a +.400 rod (6.535").
The "extra ring" you are talking about is for the heavy duty truck pistons. Your pistons should only have the standard three ring set.
wlpatterson 04-04-2014 03:16 AM
I appreciate the info,With all the smart folks out there always wanting to share their Knowledge your the only response I recieved..Again Thanx
curtisreed 04-04-2014 05:09 AM
I read your question, but I am a small block guy. Not much use to you in this case. LOL Also, there are some people I usually see answering that might not be on the NEW forum yet.
Curtis
TheYellaBrick 04-07-2014 07:21 PM
And some of us are Mopar only Freaks ! :-)
