Bbc valve adj with stud girdles
Just bought a motor solid roller cam moroso says to adj valves before installing the girdles can I set them before and then install girdles?
Set them then check them again after you install the girdles. You will be surprised at how much they can change...
| All times are GMT -8. The time now is 10:38 PM. |
