-   -   piston to head clearance (https://www.racingjunk.com/forums/showthread.php?t=34012)
ballsout1 11-24-2013 01:38 PM
i recently freshened my 383 chevy up. its got a internally balanced forged crank, 6.0 eagle rods, and je pistons. its a 12.1 vortec headed motor. i shift @ 5700 and go through the traps @ 6300. i`m now running depending on which piston and where you measure it in the hole ( on the top or bottom of the block deck) with head gasket installed from.030 to .042 . the motor had 200 runs on it and bearings were really not even broken in yet...my point being there wasnt alot of odd movement on the bottom end . crosshatch was still real clear in cylinders. soo , .030 is a calculated risk of what level?
zipper06 11-29-2013 10:06 PM
I wouldn't even worry about deck clearance, if you have .030 to.040, i would worry more about valve to pistion clearance, i've run .020 out of the blk with .043 gaskets, but had enought valve clearence. I almost always run out of the deck, except with alum rods.
ballsout1 11-30-2013 12:26 PM
i checked the deck height just so i could calculate the squish. i went from a .040 compressed thickness head gasket to a .028 and i was concerned that i might of made it too tight..... a had a .015 set in my hands too. realistically at the low rpm its turning i`m not real worried but ya never know. piston to valve is real high something like .175 and .110.
zipper06 11-30-2013 12:41 PM
In the old days GM used a steel shim gasket, only about .015 thick and put them on the street for thousands of miles.
The one engine i ran .020 out was and alum blk. with steel rods and it was turning about 7500 rpm's thru the lights. I put 200/300 runs on the engine with no problems. As long as you have very little piston rock it should be o'k with .028 clearance.
JimmySmith 11-30-2013 04:27 PM
Clearance
Iagree with ZIP. Later J.Smith 4621 racing
