-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   243 Valve Job (https://www.racingjunk.com/forums/showthread.php?t=33976)
racear2865 11-10-2013 01:30 PM
243 Valve Job
I have a set of 243. Can I go to 2.02 int and 1.6 exh without replacing seats
reed
fkqlpgaiji 09-27-2026 05:05 AM
If you’re talking about a set of 243 heads and considering 2.02-inch intake and 1.60-inch exhaust valves, I’d check the existing seat dimensions before assuming they can be reused. The larger intake valve may require enough material around the seat, while the exhaust side depends on the current seat size and chamber configuration. A machine shop can measure everything accurately before cutting. Once the garage work is done, an online casino can be a https://spinit-casinoau.com/ casual way to unwind.
