Which Oil For Break-in?
Finishing my 383 SBC and I need to pick an oil to run. I want to run synthetic but I need a break-in oil so I was looking at the Joe Gibbs line, any suggestions on which weight? I know there will be more info needed to make a suggestion so ask away. Also, which weight synthetic and how many hours should I run the break-in oil before switching?
Thanks |
If you are running a comp cam they have oil just for break in. Follow the instructions with the cam I believe it's 1800 to 2200
Rpm for 20 minutes varying the rpm but double check me on that it should be in the cam installation instructions as for weight I have used Straight 30 weight in the past for break in. After the initial break in run change the oil if it a street motor I would not use synthetic at the first change put a few hundred miles on it and change it again and use what you want as far as synthetic goes. I am not saying comp oil is better than joe Gibbs it just what I have used for break in before. |
Have used Rotella 10-40 for years as break in oil.
Which
Same here plus GM EOS additive or ZDDP additive.
This is the oil we use, we have tested all the other name brands. This is by far the best break-in oil we have found.
http://www.cnc-motorsports.com/lubri...l-1-quart.html |
Someplace back down the list of posts is a great piece of information by an independent testor . .
Go read it . . . anything put up here in this thread is either redundant or possibly just opinion. I had several of my own "opinions" before I read it . . Now I have a lot fewer! |
This is a solid roller race application with a single carb on gasoline that will be run on a stand before heading to the dyno shop, how many hours should I put on it before changing to synthetic oil? What break-in procedure would you suggest? |
Here ya go . . read it completely before you form any kind of opinion.
http://540ratblog.wordpress.com/ http://www.oilextreme.com/index.html |
Thanks!
Originally Posted by kend
This is a solid roller race application with a single carb on gasoline that will be run on a stand before heading to the dyno shop, how many hours should I put on it before changing to synthetic oil? What break-in procedure would you suggest? Go to track. Make a few passes 3 or 10 no set number, whatever you feel comfortable with. Come home cut the filter apart and change to the oil of your choice. I have been running the Amsoil Dominator racing. I have had great results with it, but I am going to be changing to Lucas 10w-30 synthetic racing oil. I can get the Lucas for about the same money, they are huge supporters of my sport, after researching I believe it will work a little better with methanol and I have never liked the way the Amsoil turns brown from red even though it doesn't hurt a thing. JMO Curtis |
| All times are GMT -8. The time now is 10:02 PM. |
