-   -   bbc (https://www.racingjunk.com/forums/showthread.php?t=33890)
tazracing 10-09-2013 05:51 AM
bbc
my 496 broke oil pump but also broke part of rear main cap. has anyone had this happen before and can you just replace rear main cap ?
zipper06 10-09-2013 08:14 AM
You can replace the main cap but will have to have the main bores line honed.
tazracing 10-09-2013 09:04 AM
thanks zip . I thought that but wasn't sure.
oldandtired 10-09-2013 10:45 AM
Good excuse to tell your wife you need a dry sump! :D
tazracing 10-09-2013 11:27 AM
I HERE YA.
markdunlap 10-09-2013 02:30 PM
BBC
Replacing a rear cap may be more complicated than just a line hone job.
Since it is also the end thrust for the crank, the new cap has to line up with the block perfectly or you may not have any end thrust.
tazracing 10-09-2013 02:44 PM
Thanks
