-   -   440 water pump housing (https://www.racingjunk.com/forums/showthread.php?t=33782)
kbartley 09-05-2013 03:07 PM
This engine being a 1978 has the bottom rad. Hose on the passenger side. I used the older housing so it would work with the radiator the guy bought. I see the blades on the pump are different also.would this make as difference since engine is a 78?
TheYellaBrick 09-05-2013 06:47 PM
THAT is beyond my knowledge base.....Mark ?
mopar1968 09-08-2013 05:39 PM
Yes it will.
kbartley 09-09-2013 02:33 AM
So I should put the housing that came on the 78 back on?
