-   -   Coolant warmer (https://www.racingjunk.com/forums/showthread.php?t=33726)
oldandtired 08-15-2013 01:54 PM
Coolant warmer
OK, I need help from my northern friends. I have a serious street car but it takes a while to warm up in the driveway. What can I use to bring the coolant temperature up, so I can crank and pull out in less than a couple of minutes?
Thanks...
fla1976 08-15-2013 02:16 PM
Still have a thermostat in it? If it is a 160 degree, change to 180 or 192. Does it have an electric cooling fan? You can add a temp controlled fan in it.
TheYellaBrick 08-15-2013 03:31 PM
Block heater or oil pan heater on a timer to turn on 1 hour before you roll.
oldandtired 08-16-2013 04:48 AM
Thanks guys.
