-   -   Vega Build, Engine Setback? (https://www.racingjunk.com/forums/showthread.php?t=33485)
kend 05-20-2013 07:15 PM
It's a drag car that'll have a 383 and Glide so before I nail it down should I set it back? If so, how far? I just bought the car and never driven it but I'm concerned about handling issues, it would be a lot easier to leave the engine where it is. Maybe I'm worrying about nothing but I would like some input. Thanks
TheYellaBrick 05-20-2013 08:58 PM
Moving your engine 'back' is going to require firewall modification and possibly additional sub frame fabrication. Lots of Vega's with V8's out there with no setback and no handling issues.
We've a couple of Vega racers here so they will have much more detailed info for ya. Welcome to the forum !
fla1976 05-21-2013 01:09 PM
I don't have my Vega anymore, but I set the engine back so it sat about the same position as the engine in a 67 Camaro I had. There was no firewall when I got it so it was no big problem. It had a V8 kit that came with the body, but It looked too nose heavy to me. I'll try to find some pics.
roadkill2 05-24-2013 06:30 AM
Depends on what you're going to do with it . . . Although I haven't built a gasser or other door car for over 40 years, NHRA still has some rules pertaining to engine setback for certain classes.
You'd probably be better off reading the rule book pertaining to the class(es) you want to run. As an example, I think (Don't hold me to it) S/G has a 10% (of the wheelbase) setback using the centerline of the spindle and the #1 spark plug as the data points.
Certain classes have certain dimensions and it shouldn't really be an arbitrary decision . .
TheYellaBrick 05-24-2013 05:38 PM
..on the other hand, if you're just running brackets, then there are NO rules except safety equipment....I think.... :shock: :oops: :oops: :oops: :oops:
fast75vega 05-27-2013 04:57 AM
6 to 8 inches seems to be the norm for motor set backs on the vega... alot keep it in the stock pos. too
zipper06 05-27-2013 07:00 PM
Set the number 1 spark plug on center with the front spindles and the car will be happy you did, and so will you. I've only built/had 2 vega's but that where they were set.
Zip
chevyart 06-03-2013 06:25 PM
vegas
join our site. h-body.org(go to forums). no charge to join and the most vega info on the planet chevy aret
ballsout1 08-22-2013 04:01 PM
fwiw... if the firewall is modified a cage as opposed to a bar is reqiured. this may or may not be a concern to ya. if your going cage than i believe the spark plug and spindle advise you got is probably about right.
