Bearings
What kind of bearings do you guys run in your motors for drag racing? I have always used Clevit 77 my motor may need to be torn down just wondering if I should look at other options. The motor is a 383sbc with Eagle 4340 rotating assembly 12.6to 1 with a flat tapped cam. I built the motor about 7 years ago.
bearings
I use king bearings and like them...
Clevite 77's
toss up between Clevite 77's and King, but now King may be the better bearing for a 4340 assy since clevite no longer makes the wider bearing with a chamfer, instead they now just make a narrowed bearing atleast for the sm/blk chevy. I know it's not much but still less bearing surface on the rods, because the bearings are amberdextrous making them narrower on the inside side of the rod. On the cast steel and cast iron cranks the bearings are still wide and ofcourse a difference surface coating.
JMO Zip. |
If I go with King witch ones would you recommend?
| All times are GMT -8. The time now is 10:24 PM. |
