-   -   Vega Rack and Pinion Kit? (https://www.racingjunk.com/forums/showthread.php?t=33455)
kend 05-11-2013 02:28 PM
I'd like to install a r&p steering unit on my vega but I have no experience installing one, does anybody make a bolt on kit for the Vega? If not, is there anything online that would help me figure it out? I've spent quite a bit of time looking for an answer to either one with no luck. Thanks
fla1976 05-12-2013 05:10 AM
http://forums.h-body.org/viewtopic.php?f=10&t=20626
This may help. :D
thegun 07-10-2023 11:36 PM
https://www.speedwaymotors.com/Unisteer-Rack-Pinion-with-Vega-Mount,27030.html
QUOTE=kend;263884]I'd like to install a r&p steering unit on my vega but I have no experience installing one, does anybody make a bolt on kit for the Vega? If not, is there anything online that would help me figure it out? I've spent quite a bit of time looking for an answer to either one with no luck. Thanks[/QUOTE]
https://www.speedwaymotors.com/Unist...unt,27030.html
aidencarter 04-30-2026 12:46 PM
Pour une installation de direction rack & pinion (R&P) sur ta Vega, c’est vrai que ça peut sembler compliqué quand on n’a jamais fait ça avant. À ma connaissance, il n’existe pas de kit “bolt‑on” spécifique pour Vega qui soit prêt à poser sans modification, donc il faut souvent faire un peu de travail sur mesure. Voici quelques conseils https://roobet.live/ pratiques pour t’aider :Recherches de base : Cherche des projets similaires sur des forums de Vega, Chevelle, Pinto, ou Mustang classiques, car beaucoup partagent des idées de conversion R&P. Même si ce n’est pas
