-   -   FUEL LINE SIZE (https://www.racingjunk.com/forums/showthread.php?t=33139)
BIGBLOCKCHEV 02-02-2013 06:17 AM
FUEL LINE SIZE
HOW DO YOU DETERMINE WHAT SIZE FUEL LINE TO RUN.I HAVE A BIG BLOCK CHEV WITH A F1R PROCHARGER AND FAST FUEL INJECTION THAT WILL MAKE BETWEEN 1000 TO 1200 HP. I WILL BE USING HARD LINE . ALSO WHAT KIND OF LINE SHOULD I USE, STEEL, STAINLESS OR ALUMINUM.
coloradoracerguy 02-02-2013 08:42 AM
I'd use teflon braided hose for your stuff, -12 to the pump, -10 from the pump to rails/regulator, -10 return. I'd stay away from hard line, just to prevent metal fatigue and cracking. Also, the biggest I've seen is aluminum 1/2" line.......
TheYellaBrick 02-03-2013 10:40 AM
It's also gonna depend on the distance you're pushing the fuel. I agree on the type/size flex hose. Anything but teflon lined will and can develop unseen and almost undetectable cracks and fractures with today's fuels. I'm changing everything of mine to it. LAST thing I want is a preventable fuel leak/fire...
hammertime 02-03-2013 11:06 AM
Re: FUEL LINE SIZE
On the procharger stuff I do -12 to the pump no matter what, -8 up to the fuel log. This is on upto 1900hp procharger stuff. I also would use braided line.
