4,400 HP !
Now that's weird for me, at first the pics and everything comes up clear then the whole background and pics goes dark, in fact so dark it's hard to see the pics. and impossible to read the print :shock:
Zip. |
http://i406.photobucket.com/albums/p...pse74c1967.jpg
http://i406.photobucket.com/albums/p...pseb1c5ab2.jpg http://i406.photobucket.com/albums/p...ps1fabb55c.jpg http://i406.photobucket.com/albums/p...psc5e863d5.jpg http://i406.photobucket.com/albums/p...ps19bec999.jpg Here are some pictures and the text for the engine. There are also links for other sites with the same engine. http://www.carcraft.com/techarticles...g_block_chevy/ http://www.nitromater.com/nhra/29275...o-mustang.html http://blogs.hotrod.com/4400-hp-mora...#axzz2JlhfKY1O It’s highly likely that at this very moment I’m the only member of the media staring at over 100 high-resolution images of what is undeniably the sexiest engine ever created by man. The images are arranged in chronological order, a veritable instruction manual detailing the assembly of a hemi-headed monster that Mother Mopar could never in her wildest dreams imagine. It’s not her fault. Except for a few race cars, Mopars were built for the masses. This masterpiece is altogether different. It was designed to ingest, compress, and explode mass quantities of atmosphere and manmade fuel, creating power to be harnessed and turned into friction, accelerating a racecar to unheard of speeds. Mike Moran’s turbocharged bullet is machined entirely from billets of aluminum and will reportedly build 4,400 hp. How? Stay tuned to Hot Rod Magazine to find out. |
Zip. TS1955 |
That there is engine porn :!: :wink:
I wanna see the Heads!
Still wanna see the heads . . All of the Head(s)!
But as a Machining exercise, it is a work of Art! On the other hand, there's far cheaper ways of arriving at 4500 HP . . Jus' sayin' . . . |
Zip, You couldn't see anything cuz just the THOUGHT of that kinda HP at your beck and call is flat azz overwhelming to the senses ! :D :D
But on the other hand they are only 500 cu in. Zip. |
| All times are GMT -8. The time now is 08:09 AM. |
