sbc carb
750 dominator on sbc
10.5:1 aluminum heads forged internals comp xs290s cam 520/540 lift im thinking a 750 dominator is a little big but how do you guys think it would work |
I'm running a mild sbc 350 with Eddies performer 70cc heads flat tops rv cam..Purchased a AED 750 dbl pumper 73 jets up front with 4.5 PV..Rear jets 80's no PV..My sb loved that AED 750...You have a bit more motor than me..My 292H cam is in route..
A 750 dominator is the same as a 750 double pumper in airflow, but a completely different carb since it's a dominator based carb. They use skirted boosters to kill airflow through the carb. It's calibration is in need of rework, as they weren't very good. So to answer your question, you'd be better off with a standard 4150 carb over the dominator, but it's still going to have to be calibrated for your combo.
| All times are GMT -8. The time now is 03:51 AM. |
