-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Crank to crank engine connector ??? (https://www.racingjunk.com/forums/showthread.php?t=32956)
wingdwarrior1 12-22-2012 01:57 PM
Have seen several tractor pullers with two & three engines connected crank to crank...what is that connector called ????
Thanks !!!
TheYellaBrick 12-22-2012 02:35 PM
This is a joke, right ? You have 'several' but don't know anything ABOUT them ? So YOU didn't build them ?
:shock: :shock: :shock: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
wingdwarrior1 12-22-2012 03:42 PM
Can ya read ???? have SEEN several...
ajk 12-22-2012 05:32 PM
:oops: :oops: :oops: :oops:
TheYellaBrick 12-22-2012 10:38 PM
Sorry dude, I never saw the seen but see the seen now ! My bad ! Old eyes and all...I'm splittin' THIS scene... :oops: :oops: :oops: :oops: :oops:
'Coupler' is the word you're looking for I believe
wingdwarrior1 12-23-2012 07:13 AM
Thanks...
Do they make them for V-6 engines ??
Plan to put 2 ,6s together for12 cyl. veh.
csx8506 12-23-2012 07:22 AM
crank to crank engine connector??
Wing,
The crank doesn't know if it's in a v-8, v-6, or whatever. If you can't get one from a store, any good machine shop can make you one.
Happy pulling
TheRabbit 12-23-2012 07:33 AM
Some multi-engined tractors run the motors hooked crank to crank. They have a coupler bolted in place of the flywheel that is splined and a coupler that fits in place of the damper pulley that is splined, and they slide together. Kinda hard on the crank that has to take the power of both motors! On the newer built tractors, all the engines are mounted separately and have their own clutch and are bolted to a crossbox, that transmits all the different engines power to the single planetary rearend.
Here's a link for you. Scroll down a little for some pics.
http://www.tedderpullingperformance.com/
itsabird 12-23-2012 12:51 PM
Pretty cool link, there rabb 8)
TheRabbit 12-25-2012 07:09 AM
I have the offroad, 4x4, mud racing, hill climbing, truck and tractor pulling, etc. stuff covered.
I have lots of other absolutely worthless information too if you need it! lol
BTW some of the engineering the tractor pulling guys do is amazing. Horsepower levels are insane too.
