-   -   Need help setting up track bar (sportsman tube chassis) (https://www.racingjunk.com/forums/showthread.php?t=32898)
rickycampbell 12-09-2012 03:01 PM
I bought the car and the ladder bar rear end was already set up. everything but the track bar. I thought about wish bone or x bar but i still got motor,tranny and odds and ends to go.Any help will be appreciated.
R.C.
TS1955 12-09-2012 06:24 PM
If you are referring to the diagonal link, you adjust it so the rear end is centered in the chassis.
TS1955
rickycampbell 12-10-2012 08:00 AM
Do i install the track bar (diagonal Link) first or square the rear to the chassis then install the track bar
rickycampbell 12-15-2012 04:22 PM
got it.
R.C.
injectedrat68 01-02-2013 02:31 PM
Originally Posted by rickycampbell
got it.
R.C.
I believe you want 1/2 the amount of total thread sticking out on each end. The other half will be threaded in the diginal link. And yes i would try and square and center as close as you can,. then connect dig. link. Dont forget to set pinion angle(get as close as you can) once motor & trans. in you can readjust.
