-   -   Fresh Turbo 400 issues (https://www.racingjunk.com/forums/showthread.php?t=32894)
Harbone 12-08-2012 01:20 PM
Freshly rebuilt Turbo 400, has reverse and 1st gear only. Those gears are tight and not slipping. Will not go into 2nd gear, at about 4K rpm I let off the throttle, feels like it slides into 2nd but then it just freewheels. If I manually shift back into 1st it bites and works fine. Vacuum modulator has vacuum and no fluid in the hose. My trans guy thinks (hopes) its the valve body and is sending me a new one.
Anybody have any other ideas or do you think my trans guy is right about the valve body?
wmeabates 12-08-2012 03:15 PM
If you are still using the electric kick down it could be in that circuit.Bill.
Harbone 12-08-2012 03:20 PM
The electric kickdown has never been hooked up
fast75vega 12-08-2012 03:30 PM
is it the same vacuum mod from your old trans or is it a new one? you might have to stick a small screw driver in it and adjust the shift point
Harbone 12-08-2012 03:39 PM
Its a new one, I will ask my trans guy if he installed an adjustable one.
fast75vega 12-08-2012 03:47 PM
for a HP street/strip car... i cant see him not using one?
Harbone 12-09-2012 07:07 AM
its adjustable but still no change. the valve body is a manual/automatic unit so even if the modulator was not working I should beable to manually go through the gears. kinda sucks, he is sending me a new valve body. if that does not fix the problem then I have to pull the trans back out :evil:
fast75vega 12-09-2012 08:48 AM
sorry... i thought you said you could shift it manually and it worked :oops:
did you check to see if the trans filter is locked all the way in cause if it will cause that very same problem cause its sucking air!
Harbone 12-09-2012 10:22 AM
It was firmly in place when I dropped the pan. I hate working on auto trannies on jackstands, damn fluid gets everywhere.
The valve body is out, now just wait for the new one to arrive and pray it works.
TheYellaBrick 12-09-2012 11:24 AM
This deserves a double AAAARRRRGGgggggg / AAARRRrrrrrGGGggggg......accompanied by serious knashing of teeth..
