-   -   Powerglide governor support (https://www.racingjunk.com/forums/showthread.php?t=32871)
travis91 12-02-2012 05:55 PM
I am rebuilding my powerglide and need some help. I took it apart a few months ago and mixed the governor support up with others on my bench. I am using a manual GM VB w/a full tree brake. I have 3 governor supports and am not sure which one was on this case with this valve body. Two of the supports are the early version with one having the priming valve still and wear plate with gasket and the other one has no priming valve and a blockoff plate and then I have one later version support with no plate that would only use a gasket. I am guessing this is basic knowledge for a tranny guy but I am at a loss. Thanks in advance for any help.
