-   -   witch way is better (https://www.racingjunk.com/forums/showthread.php?t=32812)
cervidog 11-09-2012 01:07 PM
witch way is better
I want to build a 400 sbc for drag race only.Is there any advantage to using a different size rod in my build?I will be using a stock 400 crank and want to get around 11 to 1 compression.
hink 11-10-2012 11:52 AM
If your looking for a better rod ratio, lighter piston, less piston side thrust. I would go with a 6.0 rod
cncmotorsports 11-10-2012 12:07 PM
6 inch rod would be the best choice.
TheYellaBrick 11-11-2012 09:21 AM
Mmmm...that's what my gal friend says........ :shock:
hink 11-11-2012 06:20 PM
Thats to FUNNNNNNNY
