-   -   Pontiac x body build up all pontiac 400ci thoughts ? (https://www.racingjunk.com/forums/showthread.php?t=32780)
kuhn1941 10-31-2012 03:58 AM
I am going to be building the pontiac 400ci up that is in the 73 ventura that was a bad ass race car at one time with a transbreak 400 trans manual reverse valve body with a 2800 stall convertor connected to a 9" ford with 4.10 gear and 3 link with adjustable coil overs .The car went low 10's (I was told) with a stroker motor .Now I am looking at the motor that is in the car now that I recieved it with - pontiac 1970 400ci / #17 casting heads / the race style (a stahl bolt pattern) headers 2" primary 3.5" slip on collector (too big I know, but came with the car ) edelbrock performer intake connected to a proform 650 carb .This combo feels like 14's or even slower when your driving it , so if I take it out I would like to go into the direction of more power for street strip application . In the past had sbc strokers that ran low to mid 11's in street strip cars and trucks ,but wanting to keep the pontiac all pontiac - any ideas for power from stock items that are able to be done on the dreaded budget will be helpfull , I have noticed buying the aftermarket aliminum heads will be a obvious help - so if tax refund is able that may be the last thing to get purchased .Of course those pontiac strokers put out some awsome #'s too .Thanks for input I have experienced pontiac builds in the past and they can get tricky even with a poor head choice can kill your compression down to 7.5 to 1 : no power there ! http://s1358.photobucket.com/albums/...view=slideshow
todd8525 11-05-2012 07:35 PM
pontiac build
Jan 99 Hot Rod mag. put together a 455 pontiac 529HP 558ftlbs $4000. dyno proven.It can be found under (Pontiac 455 engine buildup-alternative engine build)
TheYellaBrick 11-05-2012 07:55 PM
link no worky....
kuhn1941 11-06-2012 12:50 AM
link to the 73 pontiac ventura
http://s1358.photobucket.com/albums/...view=slideshow .sorry about the link here is the slideshow one .Thank you for the interest .
todd8525 11-08-2012 05:38 PM
try dick miller racing 662-233-2301 reading an ad about an offset ground 455 crank in a 425 olds that uses 7.0 inch bbc rods 10.33:1CR 230/236 at 0.050 0.522/0.522 cam 30 over 488CID made over 500HP and 600FTLBS.Sorry i'm not an engine builder.PS nice ride! tired of seeing nova's.
