-   -   Help with Holley Base gasket choice (https://www.racingjunk.com/forums/showthread.php?t=32656)
watertreater 09-24-2012 10:32 AM
I have a Holley 950cfm,4150 carb with a Dominator base on it with 1 5/8 inch throttle bores,the carb is 7 years old and I cannot match a base gasket to this carb,They don,t make it anymore,I can modify a square bore gasket.My question is can I use a thin open gasket between the carb and a 4 hole spacer ?
jmarksdragster 10-01-2012 05:19 PM
Got a picture of it? 950 with 1 5/8 throttle bores and a Dominator base?
watertreater 10-02-2012 02:18 PM
Sorry I don,t have any Pics of the Carb,I was as baffled as you.I pulled it off a year ago and had it rebuilt,A Holley 4150 complete rebuild kit was used and worked fine.I went to install it with a square bore base gasket the bolt pattern did,nt match up.I determined it was a Dominator bolt pattern,I called the company that built the carb 7 years ago.Bigs Performance Products.Bigs told me the the base was a Dominator base and the gasket was no longer availible. the only thing I can do is match a Square Bore Gasket and modify the bolt holes.My question was will a thin open gasket work with a 4 hole spacer?
jmarksdragster 10-02-2012 08:38 PM
Just get a 4 hole gasket and slot the holes. You could also replace the baseplate, BLP has baseplates with a dual pattern 4150/4500 or a straight 4150.
outlaw256 10-03-2012 02:15 AM
jmark, is right on this. or you can do what we have done on alot of oddball carbs. we make our own. and it always works out just fine.
