-   -   487 sbc heads (https://www.racingjunk.com/forums/showthread.php?t=32424)
hotrod1994 08-01-2012 08:42 AM
487 sbc heads
are the 487 sbc heads any good looking for a good flowing head on the street there the 487 not the 487x
thanks-logan
cncmotorsports 08-06-2012 05:51 AM
The 487 and 487X were good for there time. Still nothing close to a Vortec head, or anything aftermarket.
hotrod1994 08-06-2012 11:59 AM
ok what has to be done to a vortec head to be able to take 550 lift spring ? without running the expensive comp beehives
fast75vega 08-06-2012 03:48 PM
just need to have them machined. i believe they can only take up too a .460 lift stock. comp cams sells a tool you can chuck up in an electric drill and do it yourself if you feel the urge :wink:
hotrod1994 08-06-2012 04:58 PM
ok thanks
cncmotorsports 08-07-2012 05:30 AM
We completely re-machine the head to accept whatever cam lift we are using, guide and spring pocket.
bluedawg357 08-07-2012 07:31 AM
Is it worth machining vortec heads to accomodate lift above .500'' ? I've read that they don't flow any better past .500'' lift, is that true?
cncmotorsports 08-07-2012 02:34 PM
Yes it is worth it if this is what you have to use, or your class rules mandate it. Other wise aftermarket heads are a much better solution.
RM1 08-23-2012 04:15 PM
487 heads
for time and the money u spend on all add ons for the vortec ( valves springs covers intake oh yea they crack easy take your cash and buy a set of GM 292 turbo heads there the same as a dart 2 right out the box
487 heads
