-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   motor mounts (https://www.racingjunk.com/forums/showthread.php?t=32400)
oldez 07-26-2012 09:36 AM
motor mounts
I have a 68 javelin, I,m putting in a 350 4 bolt main,cant figure out how or what to use for motor mounts? any ideas????
olds48 07-31-2012 09:24 PM
Depending on what you want to use the car for,there are several different options. Engine plates are by far the easiest to install,but it makes accessory mounting a PITA. Best bet is to either fab up some factory style mounts,or find a shop that can do it for you. ICBW,but i seriously doubt there are any bolt-in kits for your application. Good luck!
kfqecgcw 09-27-2026 06:41 AM
For a ’68 Javelin with a 350 four-bolt-main swap, I’d first identify exactly which chassis and engine combination you have before ordering mounts. The safest route is usually to look for swap-specific engine mounts or a conversion kit designed for the Javelin rather than trying to fabricate something without knowing the required engine position. Check clearance around the steering, headers, oil pan, and transmission as well. Once the garage work is done, an rainbet.co.com can be a casual way to unwind with some digital entertainment
