-   -   roll cage for a full frame car (https://www.racingjunk.com/forums/showthread.php?t=32360)
hotrod1994 07-19-2012 08:55 AM
from what i understand i need outriggers for the main hoop to connect to the frame do i just need them for the main hoop or does every bar have to be welded/connected to the frame?
i know it belongs in the chassis section but i wasnt getting any where there
thanks- logan
BEAST477 07-19-2012 04:13 PM
Your best bet is to get a rule book from NHRA/IHRA depending on where you plan to run. Then there will be no gray areas and you won't have to do things twice.
hotrod1994 07-19-2012 05:58 PM
ok thanks beast where could i pick one up... local track?
thanks-logan
BEAST477 07-20-2012 02:43 PM
Probably the easiest way would be go to NHRA.com and order one.
hotrod1994 07-21-2012 03:45 PM
ok thanks
