400 SBC head gasket
I am at the point where i need to decide on a head gasket for my bracket motor.
It;s a 400 + 0.30, factory 509 block with brodix alum. heads. An honest 12.5 compression ratio computed with a .41 head gasket. N/A, no power adders no steam holes in the heads I am thinking a Fel pro 1003 should be adequate for a 600 hp level, but I would like to hear some opinions |
I run the same motor with Brodix track 1's except more compression. i would not run a 400 blok without using head studs vs bolts. In fact i have 2 400 blks and both are studded. I also use felpro gaskets.
JMO Zip. |
Be careful with those sbc factory 400 blocks!
We run that same gasket on a 406 that has an honest 15-1 static CR. Stock block, alum head, with studs. This motor made 702hp. Not sure how happy the dyno was but it runs low 9.40s in a 2850lb nova, shifting at 6400, leaving at 3800. It is injected on alcohol. Watch your tuneup at that hp level using a stock block. Some people get away with running them some don't. We had ours sonic tested to make sure there were no thin spots.
This was a 2bolt block with splayed caps installed. Curtis |
| All times are GMT -8. The time now is 04:43 AM. |
